Old 04-29-2023, 10:26 PM   #1
Default Large Drawer Removal
How to remove the "cooler" looking drawer on drivers side of a 2005 roadtrek 210?
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 04-30-2023, 07:07 AM   #2
many of the common drawer rails require you to pull out the drawer and then lift tilt up the front, then lift slightly and the drawer may come free.
some drawer rails may have plastic "levers" which act as a release. on some they both go in the same direction to release, on others the left side, for instance, comes up and the right side goes down ( or vice versa)
Old 04-30-2023, 01:14 PM   #3
folivier's Avatar
If there isn't enough room to pull the drawer out of the slides then pull it out about halfway and push each slide back in. Then try to release it with the plastic levers mkguitar said.
2011 Roadtrek C210P
RZR 570, Ranger 1000
folivier is offline   Reply With Quote
Old 05-09-2023, 02:44 PM   #4
As a follow up to my original post. I figured it out and have replaced the lid hinge and reinstalled.
Old 05-09-2023, 04:43 PM   #5
what was the mechanism used or the trick to get it out-- for the next guy.
