Old 03-04-2021, 06:59 PM   #1
Default Lagun Table for 2004 Pleasure Way TS
Hi Folks,
Love this forum!
Has anyone installed a Lagun table (or two) in a older Pleasureway?
If so, where exactly did you install the bracket(s)?
Thanks for any info!
Strider
Strider1 is offline   Reply With Quote
Old 03-04-2021, 09:29 PM   #2
Yes on side of passenger side chair/bench @corner between bench and bed/couch below cushions.
Ken
Old 03-04-2021, 11:22 PM   #3
Thanks! Really helpful. I had been thinking of the walkway side and was concerned that there might not be enough room. Did you need to brace the corner of the seat box at all?
Old 03-05-2021, 01:03 AM   #4
No the corner is already braced with the plywood (at least mine was) that holds the bed slats. You could add a metal corner brace if you wanted extra support but probably not necessary.
Old 05-26-2021, 05:04 PM   #5
Hi all,
Im thinking of installing second bracket in my 2004 Pleasure Way excel TS just below the tall closet behind drivers seat. Does anyone know what is located under that closet floor? I wouldn’t want to drill into anything critical! Thks!
Strider
Old 05-26-2021, 05:22 PM   #6
On ours it is the bathroom; near the outside wall (corner) is the plumbing chase for the outside shower and toilet supply, on the inside corner at the isle is a mirror and inside the bathroom the vent pipe for the black tank runs up the corner through the roof (all behind drivers seat). It should be doable as long as you are careful of whats where.
Ken
Old 06-24-2021, 04:19 PM   #7
Default Works great!
Thanks all for input. We had two brackets installed by @campr.vans and tested it out on our first trip. Both locations work great! Will try to attach pics.
File Type: jpg F9305310-6578-4E48-B08E-D2A82489194A.jpg (361.5 KB, 15 views)
File Type: jpg 89E024C0-B827-4B00-96F2-9A231B27FD91.jpg (308.7 KB, 14 views)
Old 06-24-2021, 04:22 PM   #8
Sorry. Pics are sideways. Top one is behind drivers seat. Other is at back under bench.
Old 06-25-2021, 01:43 AM   #9
Do you have a picture of the table installed? I have no idea what a Lagun table is.
Thanks
Gimblerotor is offline   Reply With Quote
Old 06-25-2021, 02:42 AM   #10
Lagun table is a popular option with mount mounted to vertical walls. I think it migrated from the marine world to the RV one. See my implementation to the galley.
Old 06-25-2021, 06:11 PM   #11
Really nice! I like your storage solution.
We put ours in cupboard usually. I learned the hard way to stow it or make sure all joints are tight before driving. It was swinging around like crazy! And that was just leaving the driveway.
Old 06-25-2021, 06:35 PM   #12
Thank you, the table top was sized to nest on the side of the galley, but for travelling I use a strap.
