Old 02-11-2020, 07:37 PM   #1
Default Kitchen Faucet Question
The kitchen faucet I used to have kicked the bucket and started leaking all the time. It always had an annoying characteristic that when turned off it would leak a blurb out. I've gone through 3 faucets (thanks to Amazon return policy) and they all seem to kick a blurb of water out after you turn the faucet off.
Is there something peculiar about RV pump/pressure systems that causes this? I ended up with a Moen which does it the least and bought another for my home laundry. The one in the laundry doesn't blurb.
Thoughts?
Old 02-11-2020, 08:56 PM   #2
I wonder if it is the level / pitch / angle of the faucet relative to true level (or even just a bit of movement of the RV caused by you).
Your home countertop, sink & faucet would all likely be level and stable so that's a difference between the RV and your home.
Old 02-12-2020, 06:30 PM   #3
Hi all, i need below response on below question please.
How can I make active the faucet’s cleaning mode of the fitting so that the sensor doesn’t activate, so I can clean the sink easily.
Jill Ellis is offline   Reply With Quote
Old 02-12-2020, 06:37 PM   #4
Faucet's cleaning mode.
Not sure if I've ever seen those three words in that order.
Old 02-12-2020, 11:37 PM   #5
Must be in the Moen Manuel
mikeehlert is offline   Reply With Quote
Old 02-22-2020, 05:20 PM   #6
Thumbs up
Oldtraveler is offline   Reply With Quote
