Old 02-04-2019, 08:51 PM   #1
Joe
Joe's Avatar
Send a message via AIM to Joe
Default Joe
We have a 1995 Xplorer 230 on a Dodge body. It has an Atwood gas water heater. No matter what I do it leaks at the plastic drain plug. I have partially screwed in and put in almost all the way. I have used Teflon tape and plumbers putty. I replaced the plug 4 times too. Nothing stops the dripping. Any ideas please.
Old 02-04-2019, 09:06 PM   #2
Tank threads corroded maybe?
On our past travel trailer I replaced the plastic (nylon?) plug with metal - then eventually, because it was so awkward to get a wrench on the plug due to nearby gas piping, I replaced the plug with a valve for use when draining - no more plug to remove every year.
I'm wondering if you mat do better with a meta plug and teflon tape?
Brian.
