Old 03-02-2021, 01:48 PM   #1
Joe
Joe's Avatar
Send a message via AIM to Joe
Default Joe
We have a 1995 Class B Explore on a Dodge 3500. I keep having to put new tires mainly on front. The belts keep slipping. I have had 3 different make of tires. The tires are Lt225/75R16 front and. LT245/75R16 on rear. Getting ready to sell but dont really want to. Just got her all fixed up. Any ideas out there please.
Old 03-02-2021, 02:02 PM   #2
Bad steering parts, could be steering gear, frame mount flex, any/all of the steering linkage, even wheel bearings, bad shocks.
Wheel alignment. If both worn on outside or inside, toe would be suspected.
Old 03-02-2021, 03:47 PM   #3
Sounds like the tire is defective, if the belt has slipped.
2008 Roadtrek 210V
Formerly:
Toyota Sunrader
Tiffin Allegro
Foretravel U225
Old 03-02-2021, 04:38 PM   #4
Do a VIN check to see if your unit was reported to be in a major accident. Bent frame, front end...
Want a B is offline   Reply With Quote
Old 03-02-2021, 05:30 PM   #5
What driving symptoms does it give to indicate belt slipping? Does it handle normally when good tires on it? Load range E tires? The odds of having belt issues in 3 brands on the same vehicle is almost certainly not the tires, and your dealer should have known that and found out what was really wrong.
Old 03-03-2021, 12:19 PM   #6
Are you buying tires suitable for the weight of the van?
Tim R. is offline   Reply With Quote
