Old 05-11-2017, 08:56 PM   #1
Angry Inverter switch in upside down
I suggest that you check the inverter switch on the control panel of your Roadtrek Ranger RT. Mine was upside down. I found it when I tried my TV, when not hooked up to AC or shore power. I turned the inverter on and tried the TV with out any luck. After trouble shooting the problem, I found out none of the lights were on. The inverter was completely dead. I found that with the switch in the off position it lite up and the TV worked.
The switch is just the opposite of all the other switches.
Also it works with the battery main switch off.
Now I see why the house battery always discharged.
The inverter switch was being left on, when I thought it was off.
Capt Ron is offline   Reply With Quote
Old 05-12-2017, 01:24 AM   #2
Ron; we have an RT Ranger ('13) - love it. Our inverter switch is ^up for on down is off. Same as the outside entry light.
Interested in any other observations.
AZ ADVenturist is offline   Reply With Quote
Old 05-12-2017, 02:18 AM   #3
My inverter switch is not "inverted" (ha ha ha), but one has to wonder about their supplier. On mine it says "shoer power"
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 05-12-2017, 02:29 PM   #4
Mine is opposite the direction of the entry light. Will get it changed.
Old 05-12-2017, 02:40 PM   #5
I always check my microwave on mine. if inverter is on the microwave lights will be on. It's gotten automatic with me
