Old 10-21-2020, 08:30 PM   #1
Default Inverter in Chevy 190 popular
Looking to install an inverter in my 2004 road trek 190 popular. I do have a small inverter in the cabinet with the water heater, but the new one is too big for there. I’ll probably put it in the cabinet under the drivers side bed, aft of the electrical cabinet, but am curious what suggestions y’all have. Thanks! Steve.
rauscs is offline   Reply With Quote
Old 10-22-2020, 01:26 PM   #2
Just checking, is the inverter in the cabinet with the water heater a 600W Tripplite inverter/charger?
Old 10-22-2020, 03:26 PM   #3
https://roadtrek190popular.blogspot....-inverter.html
Old 10-22-2020, 06:11 PM   #4
Thanks for the feedback.
Marco - it isn’t a tripplite, it is an after market unit added by a PO.
Wny-pat - thanks for the link. I’ll give that location consideration.
Steve
- Steve
'Blue' 2004 Chevy Roadtrek 190 Popular
Old 10-22-2020, 08:40 PM   #5
Here's another way from engnrsrule with the added inverter raised off the floor: https://www.classbforum.com/forums/f...tml#post104496
Old 10-29-2020, 05:15 PM   #6
otr
Default Inverter
I recently added solar and an inverter to my 2000 190V, the easiest solution was to mount the inverter on the driver side right behind the electrical cabinet area and run all cables thru the partition.
I used a 750 watt tripplite which came from a newer Chevy RT.
otr is offline   Reply With Quote
Old 10-29-2020, 07:31 PM   #7
Default Big inverter, big cables
It's best to mount a large inverter close to the battery, so there's less voltage drop in the wiring. Otherwise, you need to use very large gauge cables, which can be quite pricey. Also, keep in mind inverters need air flow for cooling. But keep your little inverter, since they are fine for small loads (chargers, TV, etc.) and usually more efficient. I leave my 375 watt Victron inverter on all the time since it only needs 4 watts to run with no load. A second Victron 1200 watt inverter requires more than twice the standby power, so it's only turned on when the microwave is used.
Nic7320 is offline   Reply With Quote
inverter
