Old 06-13-2020, 07:32 PM   #1
TheMatrix's Avatar
Default Hymer Aktiv Loft Top Gas Struts
I need to replace one of the gas struts that holds up the loft on my 2019 Hymer Aktiv 1.0. Does anybody have a recommendation, or know of a part #? Thank you in advance for any help.
Luigi
File Type: jpg bc9642676cb742dba04c6652a0a46913~2.jpg (258.2 KB, 3 views)
TheMatrix is offline   Reply With Quote
Old 06-13-2020, 07:45 PM   #2
I can't help specifically and you might have already checked but thought I'd mention that often there will be a part number printed on the gas strut. It will probably be small print & not that easy to see.
Old 06-13-2020, 08:00 PM   #3
TheMatrix's Avatar
Hadn't thought of that, but will prop the top open and take a look for a part #. Thanks for the suggestion.
