12-05-2015, 02:29 PM
How does Voltstart determine stopping?
A poster on the Yahoo board has a Zion on order and is getting the Voltstart to cool pets. It is not the typical application like we often hear about which would be a couple of hours of AC while the owners are off doing things. It is a traveling job application, so the pets are in the van all day, nearly every day. Lots of driving, also, though.
The Roadtrek site says the Voltstart kicks in at 11.5 volts, so the AC on a 185ah battery will probably have it on very quickly. It also states that you can get up to six 35 minute charging periods, and then you have to reset it for more.
Is this inferring that whenever the Voltstart comes on, it just runs a 35 minute cycle and goes off until it sees the 11.5 volts again? I can imagine the system having the van running an awful lot of the day in the above use pattern.
AFAIK, Roadtrek does not have any kind of battery monitor on Zions, at least on non Voltstart ones, so I don't see any way they could do anything but a straight timer.
I looked at how Magnum does their automatic generator start setup, as it is in the remote but not used for our setup, and they have it so you can set it up to start on voltage, state of charge, etc. You can also program it to shut off based on state of charge, etc. You do, however, need to have the battery monitor kit on it to do that. I am sure that is how davydd's system works, also, as he has real monitoring.
For the relatively low cost of a battery monitoring system, it just seems like it would make everything else so much easier and flexible.
12-05-2015, 03:18 PM
Advanced RV is programmable. I can set any SOC by % to auto start and I can set a number of minutes to run. If the battery fully charges before the runtime it will shut off. Also I can set a quiet time where it won't start and run. There is nothing in regard to cycles so I suppose it depends on the amount of fuel in the tank. It won't come on if fuel drops to 1/4 tank. I can also turn auto start completely off and the batteries will disconnect at 20% SOC.
12-05-2015, 03:31 PM
For their application, they would be better served just idling the engine and running the AC off the engine generator. We talking about racking up hundreds, if not thousands of hours, correct? I'd probably opt for the deisel engine too, since they are built for service like this. Relying on voltrek is just going to be problematic at this point.
12-05-2015, 03:38 PM
I have wondered about the Voltstart logic and the limits on number of starts and runtime. Since it is available on all three chassis I guess the interface to the vehicle could be the standard remote start feature using the same signal as a OEM keyfob or more likely they may use instead an aftermarket remote start module. Is there some technical basis for the limits on starts and runtime or are they selected for another reason? In any case once they start the engine based on low battery voltage, I agree that they can only continue to base the engine stop on runtime and they have chosen 35 minutes as a reasonable amount if battery recharge amp-hours. With the engine generator this would be no more than about 100 amp hours of charge at best with the 200 amp idle current of the aux alternator. So, the batteries can deplete another 100 amp hours before the next restart. Of course, the delay until the first engine start would depend on the initial battery state of charge so with full batteries it could be awhile before the first engine start. The only other factors are the average load of the AC and the cycle time of the AC which will depend on the weather.
Would a battery monitor improve the performance the system? I guess it could change the engine start/stop profile but the basic overall time the engine must operate to handle the charging would not really change.
It would be interesting to get some real world data a Zion with the standard AGM using Voltstart to see how it matches this in terms of restarts, number and timing. How long will it take to use up the limit of six restarts on a typical hot day?
12-05-2015, 03:43 PM
That would surely work but why keep the engine running if it has recharged the batteries in parallel with powering the AC. Why not shut off the engine for awhile and run off the batteries until you need more battery recharge? That is essentially what Voltstart is doing...
12-05-2015, 03:48 PM
Advanced RV has done it right in terms of designing a better solution than Roadtrek, not sure why Roadtrek has to rush to market with what seems like a less than ideal solution rather than take the time to design something better...
12-05-2015, 04:00 PM
Not clear. As I understand it (and I'm no expert), modern gas engines are more forgiving of long idle times than modern diesels, due to details of the latter's exotic emissions systems. This is the reverse of the situation in the old days, when traditional diesels could idle forever, albeit at the expense of trashing up the air.
12-05-2015, 04:15 PM
200 amps at idle may be a push, it will all depend on how they set up the pulleys to get alternator speed, and it will go down when hot also.
If the AC is running, they are not going to get the 200 either, as the AC will taking 1/2 of it. So by the time you have lowered hot output and the AC running, you probably would only recover 30 amps maybe in 35 minutes. This would make for an almost immediate restart.
If you used SOC to determine the shutoff, it would likely run the entire time the compressor of the AC was kicked in, and probably shut off fairly soon if it was off for a while.
Just like they are not great for running AC overnight, these setups may also be less than ideal for long day pet cooling. I don't think I would want my van starting a dozed times a day idling 8 hours of time.
12-05-2015, 04:35 PM
I think with such a small battery pack, you'd be starting and stopping the engine quite a bit in a day's time. That is a tremendous amount of unhealthy engine wear and fuel wasting. Not to mention emissions during the start and warmup cycle.
If you could choose a much larger battery pack, the equation would change alot. Someone considering doing this should not have anything less than the 400 ecotrek, and that is not really a lot of battery to run air conditioning.
12-05-2015, 04:39 PM
Agree completely that the real world performance is likely to be disappointing. I picked a best case alternator charge and mentioned that the AC load needed to be factored in. I think vans with small battery capacity are not going to fare well. Jim Hammill was just asked in Facebook how the system will perform on a Zion by the woman mentioned in the start of this thread. We will see what he says...
12-05-2015, 04:52 PM
I have seen a report of people with 400 amp hours of AGM in a Roadtrek reporting 90 minutes of AC runtime on batteries but who knows how low they ran down the batteries or how hot it was.
They also have the option for an internal DC air conditioner on some models that is supposed to be more energy efficient than the rooftop model.
12-05-2015, 04:57 PM
I could be wrong, but I thought Voltstart was only with Ecotrek/lithiums. All of those who have posted about it on Facebook have both.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
12-05-2015, 05:04 PM
On the build your van options for the Zion it is shown as a $1859 option independent of selecting the Ecotrek battery option, so it would appear to be available with standard AGM batteries...
12-05-2015, 05:15 PM
i thought that order was with ecotrek 400
12-05-2015, 05:55 PM
I have 440 a/h and can run my A/C for two hours at which point I reach 50% SOC.
Also, My Nations second alternator (which I think is the same thing that RT uses) will indeed reliably produce 200 amps at idle on my Sprinter, so that claim is plausible. As for temperature, assuming they sprung for the optional alternator temp sensor, the Balmar regulator will throttle down to maintain the temperature, so it isn't like it will get hot and stay there. I have not done the systematic observation to determine whether it in fact heats up on idle enough to reduce output. I will have to try that sometime.
12-05-2015, 06:59 PM
So, using a Voltrek run profile that triggered at your 50% SOC point, from a full battery charge, it would run the AC for two hours, then the engine would start and run for 35 min and then repeat this every hour for six cycles giving 8 total hours of AC operation. Of course any run profile would work as long as you run the engine 50% of the time once the initial discharge occurs. Assuming you can continue to get the 200 amps from the alternator over the run times. Larger battery banks just get you a longer initial time before the first generator start.
12-05-2015, 07:20 PM
But that is not a good assumption. Even stipulating the the alternator is capable of 200A continuous, the actual charge rate will go down as the battery fills up.
12-05-2015, 07:40 PM
Just an odd thought on the whole process of start/start lots of times per day with relatively small battery bank. If your battery is good for 1000 cycles (yes that is the optimistic end of the range), you could put some serious life shortening on them if you did 12 cycles per day regularly.
That said, I have read several places that the sooner a battery is recharged, the less wear it sees, but it was never quantified, and always had the caveat that the charging had to be back to totally full, which would not happen in this case.
12-05-2015, 07:42 PM
Avanti,
True, but you will be in bulk charge mode if you are adding only 50 amp hours to the batteries during the 35 minute engine run won't you? If you ran longer and got out of bulk charge mode it would be different right. Or can't you put the full charge current in during bulk charge?
12-05-2015, 07:43 PM
Definitely agree. Another argument for going lithium even if it's a smaller pack - the difference in life cycles could be realized in this situation.
