Old 12-20-2020, 05:32 PM   #1
Default How do I find more of these exterior door clips?
I have several of these exterior storage door clips on my 2000 explorer. Most of them are broken and I'd like to replace them, but I can't find anything similar. Does anyone know what I should search for?
xplorer is offline   Reply With Quote
Old 12-21-2020, 02:36 PM   #2
mloganusda's Avatar
You should check at any RV parts supplier. I think these clips would do the job. https://www.amazon.com/s?k=rv+compar...l_2889shvh79_e
Old 12-27-2020, 04:58 PM   #3
I have same problem with my 2000. I found one in a repair shop years ago, but that was the only one and when ordering more found they are no longer made. Xplorer was sold to a dealer in Elkhart. Maybe they may have some sitting around. If not, it is best to replace them with one that is more common type.
drsdig is offline   Reply With Quote
Old 12-27-2020, 05:08 PM   #4
On mine that little door is actually installed with the hinge at the bottom so it doesn't need anything to hold the door open. For that little door I think I would unscrew it from the body and flip it around. Remove the plastic Hardware and just put the screws back to fill the holes.
1998 Dodge Xplorer 230
yvairguy is offline   Reply With Quote
Old 12-27-2020, 05:18 PM   #5
They reversed the hinges on the 2000.
Old 12-27-2020, 05:35 PM   #6
I had the same problem with our 2000 and was unable to find a replacement. We no longer have it but I found that sliding a piece of paper or two between the two mating parts was usually enough to hold a door open.
Frankshay is offline   Reply With Quote
Old 12-27-2020, 07:49 PM   #7
I would just replace with a magnet and small metal plate.
Don Kohler is offline   Reply With Quote
clips
