Old 10-20-2014, 10:22 PM   #1
Ron
Default House Panel Battery Switch
Need to replace the panel switch, Sigma 2S for the house battery in my 2010 Chevy/2010 RoadTrek 190 Popular, went to my local Camping World they have only a Sigma P2-61C On-Off-On switch with the following information:
16A @ 125 VAC, 12A@250 VAC 3/4 HP
13A @ 125 VAC, 10A @ 250 VAC
10A @ 14V (T)
20A @ 125 VAC / 12 VDC
The information on my original Sigma 2S switch is as follows:
13A - 125 AC - 10A - 250 VAC - 1/2 HP - 125 - 250 VAC - 5 A - 14 V Tung - 20 A - 12 VDC
I was told by the parts service advisor at Camping World I could replace my original Sigma 2S switch with the Sigma P2-61C switch.
I question that my switch was 1/2 HP and their replacement switch was 3/4 HP was told that was no problem.
Would like to know if I can replace the Sigma 2S with the Camping World Sigma P2-61C.
Ron
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
Old 10-21-2014, 12:07 AM   #2
Default Re: House Panel Battery Switch
As the switch merely passes current, and the new one is an upgrade capable of handling more current for the same volts, it looks like no problem.
Don't commit Grammarcide. If your screw is LOOSE, you will LOSE it. Use the proper word for the context.
NLRevell is offline   Reply With Quote
Old 10-21-2014, 04:09 PM   #3
Ron
I installed the P2-61C rocker switch which is a On-Off-On disconnect switch for the Auxiliary batteries on the Monitor Panel located on the shelf above the passenger lounge seat.
When I activated, (Off) the switch nothing happened, both the Carbon Monoxide and Propane Leak Detectors lights stayed on, the ceiling lights went on when I pressed the light switch, both Auxiliary batteries where not deactivated.
I do know the wiring were correct on the rocker switch, as each wiring were marked with small white string tags.
There has to be a problem somewhere other than with the rocker switch.
Possibly someone on the forum or from RoadTrek may have a solution to the problem and would advise, would appreciate.
I also was informed by Campers Inn where we ordered our van that they do not stock the switch for the Monitor Panel.
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
Old 10-21-2014, 11:04 PM   #4
This link has some info Ron: http://www.classbforum.com/phpBB2/vi...&t=2725#p16284
