Old 10-14-2024, 08:47 PM   #1
Default House batteries
I am presently using 2 lead acid batteries in my class b. 100 ah each. I have been thinking about changing them to Eaton Agm batteries 140 ah each but when I was reading up on them they said I would need a special charger, is that true.
dutchduo1990 is offline   Reply With Quote
Old 10-14-2024, 09:27 PM   #2
Read up on inverter/charger installed in your Class B. My 2004 Chevy Roatrek has a Tripplite that has a set of dip switches one of which is for selecting Type of battery.
justducky is offline   Reply With Quote
Old 10-14-2024, 09:37 PM   #3
The AGM and wet cells charge very similarly, so if you have the Tripplite it will work as well for them as for the wet cells.
I don't recall if the Tripplites that old have the AGM setting, but if not just use the wet cell setting.
You should be able to download a manual from Tripplite online for your inverter/charger.
If you don't have a Tripplite, which I think may be possible in 2004 we would need to know what it does have in it.
Old 10-16-2024, 01:52 AM   #4
I’m using a progressive dynamics inc. model # PD 9245C for charging the two house batteries.
