Old 12-06-2021, 04:45 PM   #1
Default Hitch on a 95 Dodge RT 190v
While I had the roadtrek in the shop for a week fixing a few things (I don't think they fixed the water correctly, but at least now I get a trickle)
I saw a 96 190 in that had a square tube hitch that was bolted to the bumper brackets. I could not find a manufacturer, and have never seen one before.
Since the basement prevents doing the standard frame mount, does anyone know where I might find this mysterious thing?
I mostly want it so that I can put a bike rack on the back, however I do have a very small old 800 pound trailer that is really handy for carting things around at times.
If I can't find something I'm just about at the point where I'm going to go see if I can get a piece of square tube welded up to replace the bumper and then have a hitch welded and bolted onto that.
We're mostly floating around Arizona, technically based in Mohave county but headed south right now.
Koyote is offline   Reply With Quote
Old 12-12-2021, 08:33 PM   #2
blackbourn3704's Avatar
I have a 95D190P (Popular) with a "Drawtite" hitch. It appears custom made for the cross piece to fit in front of the existing bumper brackets, with additional brackets to carry the load. I have some pictures if you would like them let me know and I will edit them so you can tell what you are looking at.
To B or not to B? B, no question about it!
blackbourn3704 is offline   Reply With Quote
Old 12-12-2021, 09:07 PM   #3
FYI mine was "Drawtite" (I already said that)
Old 12-14-2021, 02:09 AM   #4
That's really helpful! Thanks much!
Old 12-14-2021, 02:30 AM   #5
think about a FRONT hitch kit for your dodge- I see them from time to time, that way you can use the back door.
( which I regard as a fire exit)
amazon has the 65003, this link has some pics
https://www.etrailer.com/Front-Recei...hoCohcQAvD_BwE
