Old 10-30-2020, 12:45 AM   #21
I hooked the air to the water inlet city water inlet and could get no air to pass the valve my Roadtrek has 2 tanks one inside to use in winter with the other one bypassed. From what i understand the fill valve has a valve built in to release the water in the summer tank to drain. I can not get air past that valve there is another valve that is used to use city water and will also fill the tanks.I bypassed the water heater.I do not understand the function of the fill plug.I hope this helps thanks for all the comments i really appreciate them and any more is also appreciated
robert g is offline   Reply With Quote
Old 11-02-2020, 01:28 PM   #22
Thanks. It's also help for me.
crtpnnb5rrdas5 is offline   Reply With Quote
Old 11-02-2020, 02:19 PM   #23
Welcome to the forum, from a fellow Texan!
