Old 05-16-2020, 08:58 AM   #1
Default Ground Effects Package Corner Piece
Any suggestions on where I can locate a ground effects passenger side corner piece? On the picture, the red circle is where the missing piece is, the green circle is what it should look like, but for the passenger side. Appreciate suggestions.
dchristaortiz is offline   Reply With Quote
Old 05-16-2020, 12:48 PM   #2
Maybe this post can help.
https://www.classbforum.com/forums/f...gain-9992.html
Good luck.
Old 05-16-2020, 08:45 PM   #3
I crushed my pax side corner piece backing into a picnic table. I repaired it myself using a combination of JB Weld plastic weld, fiberglass drywall mesh tape and bondo. The piece is held on with pop rivets which must be carefully drilled out, not an easy task, but dooable with care. I repainted using paint code spray touch up and clearcoat. Not perfect, but you can't tell from 5 feet away. And certainly cheaper than spending $225/ea if, indeed you can even find someone with them in stock.
