Old 11-01-2007, 03:09 AM   #1
Default Great Pleasure-Way info here
"WILLREP, Inc. is an independent RV factory representative agency for Pleasure Way Industries."
http://www.willrepinc.com/
WILLREP, INC
P.O. BOX 272016
FORT COLLINS, CO 80527
TOLL FREE FAX 1-866-257-8032
RICH WILL
800-748-1055
rich@willrepinc.com
SCOTT WILL
800-939-2248
scott@willrepinc.com
TIM DUNN
877-275-9874
tim@willrepinc.com
Their site is packed with info!
Pleasure-Way Chevrolet Production
Pleasure-Way Dodge Production
Pleasure-Way Ford Production
2008 Pleasure-Way MSRP
The MSRP calculator is fantastic!
2007 Pleasure-Way Ford Excel
2007 Pleasure-Way Dodge Plateau
2007 Pleasure-Way Specifications
2007 Pleasure-Way Brochure
The All New Lexor RL4
The All New Pleasure Way Ascent
See the links on the following page (I didn't enter a zip code):
http://www.willrepinc.com/pleasure_way.html
Great site!
Old 11-01-2007, 03:25 AM   #2
Stage 1 Welding
The first stage of production takes place in our welding department. Once each unit is stripped and prepped, we begin the process by removing the 60/40 passenger side door. Only the larger part of the side passenger door is re-welded back in its stock location. This door acts as the side entrance door into the unit. This process enables us to maximize the space of the kitchen area. The supporting roof cage is then welded in to place.
I didn't know that!
Old 11-01-2007, 03:30 AM   #3
"Reinforcing side body supports are welded in place in order to provide support for further installation. Since the Dodge Sprinter Chassis is a uni-body structure, modification to the stock chassis is very limited to allow Pleasure-Way fabrication."
Old 11-01-2007, 03:36 AM   #4
"E 3500 Ford chassis ready for production"
"Stock E 350 Ford chassis stripped"
Wow! Seems like a lot work!
Old 11-01-2007, 03:39 AM   #5
"All Pleasure-Way Van Motorhomes are not produced on an assembly line. Each van motorhome is produced by a process called stall installation. This means that during the building of the interior, the van stays in one stall while the other departments such as plumbing, electrical, propane and cabinetry rotate through the van."
