Originally Posted by booster
I don't remember all the correct chemical basis for the types of anti-freeze, but I did a bit of reading on the subject a couple of years ago, when deciding whether or not to switch our 07 away from Dex-cool. Don't believe the dealer, they have had lots of problems. Sludged up 4.3 engines, failed gaskets on lots of others.
I was a bit surprised when they said intake manifold gasket, as I thought it mostly affected smaller
displacement GM engines, like those you mention. I was expecting it to be a water pump, based on where the
coolant was found under the van.
The Readers Digest version would be:
Dex-cool is not the best choice, but if changed more often than recommended it will not eat gaskets, plus the newer engines have improved gaskets. The most important thing is too make sure there is never any air in the radiator. Make sure the coolant tank is at the right level and the hose clamp not sucking air. Air and Dex-cool seem to be the fatal combination.
I did read that about the air issue. It made me wonder about the coolant recovery reservoir, and generally how
you could prevent air being sucked into the system? I have never removed the rad cap, as I have never needed
to, using the reservoir to add coolant if necessary. I also wondered if it might be more than the coolant,
perhaps the gaskets themselves are lousy, or the design of the heads, manifold, block channeling is just
more prone to problems? So changing coolant types might not buy you much in the long term.
When I asked, if I stayed with DexCool as my coolant choice, whether I'd have to do this again in another
180,000 kms? Answer, non-committal. I asked if the gaskets had been improved or were they using a better
grade of gasket (mine is a 2002)? Answer, again, no, it's a factory gasket replacement.
That made up my mind to switch, more or less. DexCool and a factory gasket had failed for me, so why not
try something else?
Using plain old green antifreeze has been done by lots of folks, mostly with good success, but it does not have the best corrosion package for modern, lots of aluminum and alloys, engines.
Saw a fair number of people mention it as a possibility, and if it's less prone to error (air exposure, less acidic,
less corrosive) it might make more sense for the masses. Some people have no idea about changing fluids
at regular intervals. Throw in DexCool with it's apparent, and undocumented, shorter lifespan and you're bound
to have issues like this. I tend not to add extra water to my coolants up here on the tundra, in my Escape for
example, and have never had any other gasket problems, with any other car, ever. I've owned a dozen or so,
all shapes and sizes.
Best choice to go for when getting rid of Dex-cool would be a Honda style anti-freeze. As I said, I don't remember the actual types, but the Honda style has the corrosion inhibitors for the newer engines, but a different chemistry that gets rid of the Dex-cool type problems.
Got a brand name, even? I'll be switching to the green stuff as of this week, and if there's a better "green stuff",
I'd love to know more about it. I don't want to have to do this again, not that this engine will likely see a ripe old
age, but they didn't mention any other side effects from this problem. I believe it's been caught in time. I haven't
noticed any performance or other symptoms of fluid cross contamination. Everything will be changed after the gasket
replacement, on spec. And time, of course, will tell. I'll ask at my nearest Honda dealer, or maybe Canadian Tire
about their version of coolant.
That said, I decided to wait until the 5/100K warranty is off our 07 (Oct of 2013) to switch from Dex0cool, as the change would void the warranty, but will be changing it this year at 10K miles. After that it will be on Honda spec anti-freeze.
I don't have the warranty issue to wait on, so I'm pulling the trigger now, and switching to anything but DexCool.
I wonder if the green stuff comes in GM/Ford/Honda/etc. versions? Or is it "one size fits all"?
