Old 08-04-2020, 05:48 PM   #1
Default Gasket/sealant for Water Heater Door?
Hi Guys,
I'm replacing my Suburban SW6D in a 1996 Roadtrek 210P.
Question: What product(s) do I use to build up the gasket/sealant on the outside water heater door?
Thanks!
~g
gkise is offline   Reply With Quote
Old 08-04-2020, 09:34 PM   #2
eric1514's Avatar
Butyl Tape?
LINK
"Il Travato Rosso"
2015 Travato 59g
Old 08-04-2020, 10:20 PM   #3
That looks like the answer!
Now I have to figure out how to remove the old stuff...
Thanks!
~g
Old 08-05-2020, 05:31 AM   #4
I replaced an external outlet cover and used the tape. I believe I used mineral spirits to remove the residue from the old tape. Washed it off and then put a coat of wax on before installing the new tape/outlet cover.
Old 08-05-2020, 05:40 AM   #5
Awesome! Thanks! I just ordered butyl tape. Looks like it'll do the trick.
Old 01-22-2022, 07:51 PM   #6
This could be long shot but could be the best solution. Hein makes profiled gaskets for fan van roof installations, he could make a specific gasket on his CNC machine assuming you have 3D drawing. Good luck. https://diyvan.com/
