Originally Posted by phantomjock
Chevy 2500 I assume? Thanks for the "Links." I wasn't looking for an excuse to crawl under the front end again! Red or Black?
I note the Moog K700537 is listed for the Ford Mustang. Amazon says it fits. I shoulda' had these when I made the "Lift." Oh well. It will be nice to add them now and put "pencils down" on the front end.
Cheers - Jim
It is interesting on the end links being that much better than stock unless the stockers were old school rubber ones.
By 2007 GM had switched to what are probably hard polyethylene end links that are very hard and incompressible so would very likely to give handling similar to aftermarket urethane. The privot bushings, I don't recall what they are made of, I will have to look.
With the end links, IMO, it is important to have the van level and on the ground when you tighten the links, so the bar doesn't wind up preloading the suspension (unless you want it to because of uneven weight distribution).
