Old 11-04-2018, 03:42 AM   #21
Oh I'm not sure if I mentioned that also when I was able to see the flame I noticed the ignition spark was still firing when the flame was lit so that tells me there's a problem with either the thermocouple or the ignition module (as well as something else possibly).
And another thing I didn't want to mention at first (because I wanted to ensure biased free advice) is I found someone had wrote "new ignition module - rv fridge" on the user manual. But I don't want to assume they knew that was the problem.
Deiganator is offline   Reply With Quote
Old 11-04-2018, 04:24 AM   #22
Here's something that may help you out.
http://rvrefrigeratorrepair.com/wp-c...rvice-600-6100
Old 11-04-2018, 04:26 AM   #23
The guide does list the pressure needed. Somewhere I read that you also need 12v minimum. I believe that your flame should be blue, not yellow.
Old 11-04-2018, 04:31 AM   #24
That's gold! Thanks for that
Old 12-10-2018, 11:11 PM   #25
Hi all, been awhile and wanted to update you!
So I went through the entire troubleshooting guide on the provided service manual (except check LP pressure) and I've ruled out everything but the LP pressure and ignition module.
I want to get full LP inspection anyways for the RV, so that's why I haven't made my own manometer for the fridge. I'll just get it all inspected at once when I insure it in February. So hopefully it just needs a new LP regulator and maybe oil blown out of the lines as I suspect it may be the pressure due to some sputtering that just started happening now which is after I've cleaned everything out very well. In addition, I think I see yellow flame tips both on the fridge burner and the stove (see pics).
Stove flame:
Fridge operation/burner:
So for now I'm just waiting for February...
