Old 10-12-2020, 10:05 PM   #1
jls
Default freshwater tank fill cap missing?
wondering if there should be a cap on my freshwater tank fill hole? it's for a 2019 sprinter / 2020 roadtrek agile... the location is inside the passenger door so it's basically covered when the door is closed but totally exposed when the door is open. not sure if that's the way it's supposed to be?
jls is offline   Reply With Quote
Old 10-12-2020, 10:41 PM   #2
On Ebay - "Roadtrek red plugs for water holes Tapered 1.28 top 1.17 bottom Pull tab center" Seller is a Roadtreker.
If that doesn't work they are made by Caplugs, Erie Pa. You can request samples at: https://www.caplugs.com/center-pull-...d-plugs-cpt-nf
Old 10-13-2020, 12:55 AM   #3
jls
thank you
Old 10-26-2020, 05:02 AM   #4
They're for sale on page 23 in this inventory list:
https://www.mobiliferv.ca/rv-parts/roadtrek/?page=23
Buford Wilson is offline   Reply With Quote
Old 10-29-2020, 06:04 AM   #5
jls
thanks for sharing that great resource for all sorts of Roadtrek parts
