Old 07-04-2023, 11:32 AM   #1
Default Fresh water pump normal operation.
When turning on the water pump, it just keeps running. Shouldn't it turn itself off once pressure has built up and then resume once a tap is opened? I'm new to RV's so forgive my ignorance.
The Eyesore is offline   Reply With Quote
Old 07-04-2023, 11:56 AM   #2
You are correct. The pump should turn off once pressure is reached. Pumps are low pressure activated. If it continues to run means something is amiss.
Check to make sure all valves are turned off. If pump continues to run, look for leaks. Could be a faucet connection or pex crimp. RV's are like earthquakes when driving. The results from constant jostling is leaks occur.
2016 PW Lexor TS
Old 07-04-2023, 03:01 PM   #3
One very common cause of continuous pump running is the clear plastic cap that fits over the debris screen that many pumps have.
There are several potential issues:
--The plastic cap is cracked due to freeze damage
--It was installed without its O ring
--It is cross-threaded
--It just wasn't tightened adequately
This happens to almost everyone at some point.
Old 07-04-2023, 04:00 PM   #4
These pumps have small valves to keep pressure up. Any small debris will cause their leak. Taking your pump apart and clean it can solve leaking issue.
Old 07-04-2023, 06:56 PM   #5
Thank you all. The first item I discovered is the blowoff valve at the water heater, doesn't seal. I'll start there.
Old 07-05-2023, 06:03 PM   #6
I recently found mine to be dripping when water heater was on. I took out the anode and flushed the entire water heater out with a wand tool. Lots of white gunk. During the washing I flipped the pressure relief valve open and shut a bunch of times. Put in new anode, refilled and dripping has stopped.
Old 07-09-2023, 04:56 PM   #7
For me, the most commone reason the water pump runs continuously when turned on is that I neglected to close the city water fill valve after filling the water tank.
2007 Chevy Roadtrek 210 Popular.
Roadtreker357 is offline   Reply With Quote
Old 07-09-2023, 05:10 PM   #8
Default Water pump running
I would pull the water filter and change it out, if it is seriously dirty it will cause the pump to run as it cannot build up pressure.
Alfa2600 is offline   Reply With Quote
Old 07-09-2023, 05:28 PM   #9
After replacing the pressure relief valve, it now holds pressure. Thanks people!
Old 07-09-2023, 06:07 PM   #10
Check for leeks
Makes sure outside shower hot and cold closed so not reserculating
Check any waterheater bypass valves set correctly. Also reserculates water
twirz is offline   Reply With Quote
Old 07-10-2023, 01:42 AM   #11
Ditto with me and my rig, Roadtreker357.
2015 RT SS Agile
skier1950 is offline   Reply With Quote
Old 07-10-2023, 08:33 AM   #12
Originally Posted by twirz View Post
Check for leeks
Thank you! I didn't think of those.
