Old 08-29-2016, 04:35 AM   #1
Default Fiberglass thickness
Trying to plan my cable entries for a future solar install.
I was thinking of using a couple of cable grips/gland nuts to make sure the entry is liquid tight, but I am not sure if they have enough thread to make it through the roof.
So, how thick on average, are the fiberglass shells/roofs?
silverchris is offline   Reply With Quote
Old 08-29-2016, 05:55 AM   #2
if you have a roof vent, you can check there by removing the inside trim pieces - or if you have a crank up antenna- you could remove the trim pieces and see.
My 2006 PW lexor roof is about 3/16" I'd guess.
