Old 01-09-2024, 03:31 PM   #1
Default Fiberglass separating from frame
Hi, first time posting, RT 210 owner since 2011. I see a gap developing between where the fiberglass shell meets the drivers side door frame. Does anyone have a suggestion on how to reattach the fiberglass to the frame or know how they do it at the factory? JB weld or an epoxy of sort? Thanks in advance.
Rauk is offline   Reply With Quote
Old 01-09-2024, 05:47 PM   #2
I had same thing happen on my 2006 RT 210P. Had a local auto body shop repair it. First repair failed when the crack reappeared in a few months. The shop owner checked with another shop that did fiberglass work. He did the repair again and it has been perfect for over 2 years now. I should have asked them what material they used.
I suggest you go to a shop that does fiberglass repair work. If you can find a shop that does Corvettes that may be best. Boat shops are another option.
Old 01-09-2024, 05:48 PM   #3
Thanks! I’ll check out those options you suggested.
Old 01-14-2024, 05:41 PM   #4
Default Even in my 2019C210P
I had my shell separate at the same spot, at the seam and attachment point behind my driver door. I live near Kitchener and took my van to a spot recommended by my local Roadtrek service centre.
LimboMan is offline   Reply With Quote
Old 01-15-2024, 03:59 PM   #5
Thanks! My 2007 210p is put away for the winter but I will check around some more to find the right spot. My RV guy never heard of it happening but I appreciate all the help I’ve gotten on this forum. I’m seeing around the side entry door now too.
Old 01-15-2024, 04:14 PM   #6
This crack eventually led a a gaping crevice with panel separation
