Old 02-17-2021, 12:44 AM   #1
Default Dometic RM2354 Refrig DC Heater
I have a Dometic RM2354 refrig. I am looking for a replacement 150 W DC heater. The original part number is 0173735069. I am unable to locate such a part number. I realize the part number may be updated but I am unable to locate it on Dometic's web site nor via an internet search. No superceded part numbers are showing up. I recognize that a universal type replacement may fit/work.
Any assistance with part numbers or sources is appreciated.
Thank you all.
Roadtrekrob is offline   Reply With Quote
Old 02-17-2021, 04:55 AM   #2
You would be better off replacing it with a 175 watt heater from a later model. I don’t have the part number anymore but it does exist. I’ll post it if I find it. Don’t waste your money on the 150 watt part.
Here is your part number.
3850646104
Dyers isn’t known for low prices but they have the best price I found.
https://www.dyersonline.com/dometic-...g-element.html
Old 02-17-2021, 12:54 PM   #3
3850646104
Or maybe better off, I was, moving to only ac or propane, More Heat. About 2 years later I went to put a Large load on the battery, dc did not work so I just fliped over to ac. I was curious, so I checked at the connecting block and power was there. With my old memory I don't recall if there was power on the both sides!
Old 02-17-2021, 09:43 PM   #4
You can ask for a quote there : https://1000islandsrv.com/
I got mine 120v from them. Beat any price I saw.
They are located in Ontario. But can surely ship to US.
pomerlo is offline   Reply With Quote
Old 02-18-2021, 12:46 AM   #5
3850646104
hbn7hj:
Thank you for the part number. I will pursue that avenue if I am unable to repair the existing heater. The tab for the power connection wire at the heater came loose from the heater. I will try to solder it back on tomorrow.
Old 02-18-2021, 12:57 AM   #6
Bud:
Are you referencing the power block behind the refrig where the line side DC power comes in?
Propane will not stay lit while driving. I don't believe that I have AC inverted power to the frig when driving (I checked some time ago), but I have since repaired another problem so I will further verify what I have.
Thanks also for the part number and the possible source.
Old 02-18-2021, 01:07 AM   #7
Pomerlo:
Thanks for the info. I will follow up if I cannot repair the heater that I have. I was trying to be proactive with the post.
We are again driving more than 1,000 miles round trip this weekend to get our second Covid shots so I am hoping to get it repaired prior to leaving. I removed the frig to add the cooling fans. I nudged the heater wire by accident and the tab broke loose from the heater, thus the additional repair.
Old 02-18-2021, 01:46 AM   #8
Originally Posted by Roadtrekrob View Post
Bud:
I do not know or recall exactly the routing of the dc cable from the dc fuse panel inside, just that I may have not checked for dc where the refrigerator cable connects with the cable from the fuse panel, that side of the connecting block.
At the moment I can't recall any B with inverter ac power that can be used with the installed refrigerator. The folks running on ac have made it happen. Again I chose to use ac maybe 2 years prior to learning it did not work, really a noticeable difference with an absorption to start with and then a lousy installation, roadtrek. It was really simple with my 05/04 190P (like it). Mine all manual, no ac except for heat. But it runs on ac automatically if I us ac, shore power, then generator, the inverter. That is if I turn on the inverter when driving off from the house.
My propane would also blow out, so I modified it and could drive in still air 80 or more in still air. But there is not a lot of still air. I can mostly drive on interstates without a problem, don't rarely do. It is mostly ac here.
I didn't suggest a part, hbn7hj. If no solution when needed, maybe modifying the air flow for propane, but I don't know. If a roadtrek 190 like mine, call me.
Old 02-18-2021, 06:04 AM   #9
Pomerlo:
It will work better with the 175 watt heater. You have access, replace it.
Just an opinion.
