Old 07-29-2014, 04:14 AM   #21
Default Re: Dometic RM2310
Well, the fridge is up and running but it was a strange road to get there.
I started through the troubleshooting guide. Checking all the wiring behind the fridge, I noticed the DC neg ground cable was loose. Tightened it up and re-checked. No good. At least that would explain the pathetic DC performance.
Checking all the other wires and connections, they looked good. Put a voltmeter on it... 11.5 volts at the terminal. That should be good enough to light. Checked propane...it's flowing to other appliances. Took the door and the bottom cover off. Unfortunately I can't get the switches and lighter that way. I'll have to get at them through the back.
So I'm poking around in the back again looking at how to get the switches out and my hand brushes up against the heater unit. It's hot. What the ? I turn the fan off and listen carefully. I can hear the burner going! I go back to the front and check the sight glass. It's clear, no indication that the unit is in operation. I go back a few hours later and confirm that the fridge is starting to cool down.
So the bottom line is that I guess it was working the whole time. I never left the propane on long enough to find out because I always trusted the sight glass to indicate if the burner was operating. Crazy.
Raindem is offline   Reply With Quote
Old 07-29-2014, 12:16 PM   #22
Mike's Avatar
I wonder how common that is? Is the flame supposed to be blue? Maybe in the dark it's more visible?
Glad I have the little meter, but I might have to use touch as a fall back next time mine won't light.
Old 07-29-2014, 02:39 PM   #23
Originally Posted by Mike
...but I might have to use touch as a fall back next time mine won't light.
Worked for me. I figure the touch method can be useful for other things too, like testing if an electrical outlet is live. Don't need no stinking voltmeter!
Anyway, thanks again for all your help.
Old 07-29-2014, 03:51 PM   #24
Mike's Avatar
No problem. I learned from it as well.
The invoice is in the mail.
Old 07-29-2014, 05:27 PM   #25
Johnny R's Avatar
For my unit, I plug into 110V and turn fridge on for several hours before stocking, to bring it down to desired temperature. Also, the RV must be parked pretty well level for the fridge to work properly.
W.R.T. the lighting: if the propane was shut off at the tank before the fridge was shut off, you may have to draw the propane through the long feeder line by keeping the knob depressed for more than a minute before pressing the igniter .
Johnny R
Johnny R is offline   Reply With Quote
