Old 11-26-2019, 11:13 PM   #41
Bruceper's Avatar
Originally Posted by GallenH View Post
I don't know if I sent you any service documents. I have one that covers models RM2310 thru RM2810. Do you want it?
I would be interested in the RM2310 service manual if you wouldn't mind.
Old 11-26-2019, 11:36 PM   #42
Here goes. I've done photos before. Not sure about pdfs. This doc originally covered all of the stated models. I eliminated all of the info unique to other models. The electrical circuit drawing following the one originally in the manual is mind. I was trying to deduce the wiring in the junction box. All comments in red are mine including the one on the diagram that I mistakenly labeled the 12v supply wires incorrectly.
Dometic RM2310 only Service.pdf
Old 11-26-2019, 11:37 PM   #43
Sorry on the above: not "mind" but "mine."
Old 11-27-2019, 03:03 AM   #44
Here is the complete Dometic doc for those of you that have models other than the 2310.Dometic RM2310+others Service.pdf
Old 11-28-2019, 01:21 AM   #45
Bruceper's Avatar
Attachment 8415
Worked, thank you very much!
Old 06-25-2021, 12:19 AM   #46
Default ! Uncrimped Wire behind Fridge
Hi all, we have a 2005 PW TD; we recently picked up this rig and for the past 2 months we have been working out all its little bugs...a complete shake down. And just the other day my husband removed the outside covers for the backside of the Fridge, as he was preparing to vacuum out the back compartment, and he happen to find a wire that had come uncrimped ( has since been repaired). All wiring looked to be untouched since factory build. Don't know if this wire is Fridge related, however, it seems that the unit is cooling off faster and maintaining better level of temp.
Santee2005PWTD is offline   Reply With Quote
dometic, not cooling
