Old 10-24-2018, 08:43 PM   #1
Default Dometic Fridge problem
I have a nearly new unit with a Dometic RM 8505 Fridge. The lights continually flash with a beep every few seconds. Dometic support says it thinks the door is not shut properly. I can't even turn it off! (Maybe by pulling a fuse I suppose)
Seems that the door is shut properly as far as I can see and feel.
Anybody know how to handle this problem?
Thanks much!
foxman is offline   Reply With Quote
Old 11-08-2018, 10:49 PM   #2
Default Dometic fridge beep and flash.
I recently replaced my 3 way dometic fridge. I put it to the test of each to see operation of each and was happy of performance of each way . The last test was DC mode which worked fine for 3 days. The 4 day I saw all lights flash on and off continuously plus a beeping sound. I thought I was going to pull the fridge and send back to the vendor for replacement until I realized the DC voltage was too low to operate fridge this causing to go to error mode. Once I charged the battery, no more bells and whistles, everything back to normal.
dnnytlsn@yahoo.com is offline   Reply With Quote
Old 11-09-2018, 10:40 PM   #3
Watch out for some Dometic fridges, there's a class action lawsuit regarding some of them catching fire. Gas absorption models. Details here:
https://www.hbsslaw.com/cases/dometic-rv-refrigerators
UKDude is offline   Reply With Quote
dometic fridge, fridge door latch
