Old 01-06-2016, 05:13 PM   #1
Default Does my hot water heater need clearance on the sides?
I'm thinking of extending my sleeping area by squeezing a plywood panel 3" closer to my hot water heater. The heater is a standard foam-octagon thingy that I've seen whenever I Google "rv hot water heater." The extra 3" will be huge for me (I'm 6'3" and my sleeping area is only 6' long)
Do I need to have a certain amount of space between the outer foam edge of the heater and the plywood/particleboard/whatever it is, or will I be okay squeezing the board right up to the edge of the heater? Could I mitigate any potential issues by installing some standard hot water heater insulation wrap around it beforehand?
(I would move the heater if I could, but of course it's installed to line up with the big ol' hole in the chassis, so that ain't happenin')
Thanks so much!
Straylight is offline   Reply With Quote
Old 01-06-2016, 06:49 PM   #2
Boxster1971's Avatar
I have the installation manual for my Atwood water heater, but it's too large for this forums 2MB pdf limit. It has a standard foam outer shell. Page 2 indicates you can do a zero clearance installation, so you should have no problem doing what you propose. Im attaching a copy of page 2 from this manual.
Hope this helps,
- - Mike
Old 01-06-2016, 07:40 PM   #3
Awesome, thanks for clearing it up! I bet mine's the same way.
