Old 04-02-2024, 01:33 AM   #1
Default DIY Solar Panel Wiring - Roadtrek Simplicity
I've got a nice DIY solar panel on my 2018 Simplicity Roadtrek - and a simple solar charging controller -- all works fine -- EXCEPT... Until now I have had to run the wires outside the van because I just could not find a way to get them from the roof to the battery region in any elegant way. I was looking at going through the AC hole, but my fishing expedition was a failure.
Any Ideas?
Thanks,
Gary
grondeau is offline   Reply With Quote
Old 04-04-2024, 11:17 PM   #2
TomF's Avatar
I ran the solar panel wires through a thru-hull fitting that is watertight. They are available at marine supply stores. I put it on the vertical part of the roof at the rear of the truck, and ran the wires to the controller mounted on the cabin wall.
1997 Roadtrek Popular
Old 04-04-2024, 11:21 PM   #3
Thanks Tom,
I used the vent pipe as the feed through. Saved poking another hole in the shell... Worked fine.
solar roof feed-through, solar upgrade, solar wiring
