Old 09-06-2019, 02:48 PM   #1
Default DEF issue. Help please
Hi All!! I am new to the forum and have not done a proper intro of myself. I am hoping someone can help me better understand my possible issue before I go to the mechanic today.
I have a 2016 Travato 59K diesel. I added 3 gallons of DEF from a pump at a Pilot truck stop. I then drove approximately 100 miles and my engine light came on. I am now getting a reading on my dash that says I need to go to the dealer and have my rig service due to DEF.
I have a code reader and it is saying the code is NOx Exceedance.
Has this happened to others and should I be as concerned as I am now?
Also I am from Massachusetts and am in Yellowstone on vacation. So not the best timing for this to have happened but I guess there never is a great time for it either.
Thank you for any help and information
Aaron
Aaron Travato 59K is offline   Reply With Quote
Old 09-06-2019, 04:09 PM   #2
Aaron
I can't help you much, since all my experience is with Sprinters, but:
EXACTLY the same thing happened to me in my MY2014 Sprinter-based rig. In the Sprinter, this fault puts you in a "x starts remaining" state, so there is no choice but to treat it as an urgent repair. I hope the Promaster is more forgiving. In any event, I ended up having both NoX sensors replaced under warranty.
The following is total speculation, but I have since stopped using DEF from the big-rig pumps. My theory is that maybe putting relatively cold DEF from an underground tank may be bad when introduced into a hot engine. This may be total BS, though.
Old 09-06-2019, 04:23 PM   #3
Hi Avanti
Thank you for the reply. I think you could be onto something with the cold def in a hot engine.
I talked with a mechanic this morning. He can look at my Travato tomorrow. In the mean time he said I should take it on the highway and see if the code clears. As of now I do not have an X amount of starts showing although I am concerned that could happen.
Thanks again for the help
Aaron
