Old 08-02-2018, 11:35 PM   #21
Originally Posted by Roadtrek Adventuous RS1 View Post
What make model and year is your vehicle?????
2015 Winnebago Era.
Abn1SG is offline   Reply With Quote
Old 08-02-2018, 11:37 PM   #22
Which is why the aforementioned ScanGauge X-code is interesting. I need to get around to trying it.
Will be monitoring this post for more info on this ScanGauge.
Old 08-03-2018, 05:32 AM   #23
Knit's Avatar
Default DEF for Sprinter?
You need to have newer scangauge firmware 4.22 or higher.
Scangauge web site has these codes for 2014+ Sprinter. https://www.scangauge.com/x-gauge-commands/mercedes/
Here is the info on DEF level. Says it’s for 2014+ 2.1 L. https://www.scangauge.com/xgauge/die...r-2-1l-diesel/ and https://www.scangauge.com/xgauge/def-level-lwn/
Has anyone tried DEF code on 2012 3.0 L 6 cylinder?
Knit is offline   Reply With Quote
Old 08-03-2018, 02:11 PM   #24
I did not see a DEF scan gauge for the 2014+ 3.0L. Do they not have one?
Old 08-03-2018, 04:36 PM   #25
There are several (at least three) different X-codes floating around that claim to read DEF level--I am pretty sure some say they are for the 6 cyl. Obviously, I can't confirm. Google around a bit.
Old 09-22-2019, 01:55 AM   #26
The service manual for the 2014 Mercedes Sprinter 3500 says the following:
"Fluid should be added regularly to the DEF supply reservoir during vehicle operation or, at the latest, after receiving the first warning message via the on-board computer."
(emphasis added)
