Old 03-27-2021, 01:03 AM   #1
Default counter top replace
I have a 2004 chev 3500 190 popular that is in dire need of a counter top sink replacement.Any idea's. thanx......Fredster
Fredster is offline   Reply With Quote
Old 03-27-2021, 01:13 AM   #2
the sink itself?
I'd expect a "bar sized" stainless sink would do it
size it for the opening and the depth for the space below for the drain plumbing.
is you faucet mounted through the counter top or through the sink surround?
mike
Old 03-27-2021, 03:21 AM   #3
counter and sink are one mouled piece
Old 03-27-2021, 01:15 PM   #4
eric1514's Avatar
I'll be the replacement won't be. But seriously, It would be easier if you thought in terms of a counter top separate from the sink. You'll have more options and I would think it would be a lot cheaper. If your determined to stay with a one piece, start searching for companies that make cultured marble items like vanities or showers.
"Il Travato Rosso"
2015 Travato 59g
Old 03-27-2021, 04:36 PM   #5
We are building our van with a stainless steel countertop with the integral sink to save weight. ARV is building it and they have built another van already with it and you can see it in this video right at the very beginning and later describes it:
Old 03-27-2021, 06:20 PM   #6
Ditto.
Formica counter top can be cut and finish in many places. There are many choices for sink from Home Depot house style to marine/RV with glass lid. https://pantherrvproducts.com/sinks-faucets/
I have HDPE countertop (same material is used for cutting boards), it was CNCed, easy to clean, looks good, reasonable for wear, but it is sensitive to heat.
Old 03-27-2021, 06:59 PM   #7
counter and sink are one moulded piece
cut a hole and stick in a sink?
my pleasure way has separate sink from the countertop so more conventional.
a separate sink opens up your options.
while we do have a cover for the sink, the pleasureway has counter area, so the sink is left uncovered and while driving is a repository for stuff we don't want falling
mike
Old 04-01-2021, 05:30 PM   #8
Our 2004 RT 190 Popular counter top is warped. I have seen several like this from that general vintage. Roadtrek told me that the counter top/sink is structurally part of the larger cabinet system no practical to remove and replace, For what that might be worth.
BJ
Bjones7788 is offline   Reply With Quote
