2014 Chevy Roadtrek Popular 190. Worked fine last time I used it a month ago, but it's not getting cold now. Outside temperature is about 85 degrees and inside temperature is about 72 degrees. Thermostat is set to cool and I turned the setting all the way down to 60 degrees. Fan comes on and I thought I could near the compressor cycle on, but it doesn't seem to make as much noise as usual, and the air coming out is pretty much room temperature.
What should I be checking?
