Old 07-21-2024, 04:53 PM   #1
Default Collision Damage
I got hit, driver side.
Where do you take a class B for repairs?
Toolman0114 is offline   Reply With Quote
Old 07-21-2024, 09:20 PM   #2
Any body shop. Take the water heater out for them.
Old 07-22-2024, 01:24 AM   #3
I contacted my insurance company, and they suggested a local body shop that I knew had a good reputation. My damage was just cosmetic and just required a paint job fortunately.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 07-22-2024, 01:33 AM   #4
A lot will depend on if you can find a body shop that can pull that out from the outside or not. If they need access to the inside of panel, that means whatever is on the inside would need to be removed and reinstalled after the repair. The interior work would have to be at an RV shop, I think, as a body shop won't want to mess with it.
Could get very expensive, and depending on the value of the van, the insurance might total it out. You could buy it back pretty reasonably and still get it fixed, but it would carry a salvage or rebuilt title which would reduce it's value.
It appears there must be a filler panel in there where a sliding door would go and the seam has opening up, so the whole filler may need to be replaced.
Old 07-22-2024, 05:31 AM   #5
I repeat. Do not let an ignorant bodyshop take out the water heater.
Old 07-22-2024, 11:54 AM   #6
Thank you, I’ll make sure it’s done by experts
Old 07-22-2024, 11:55 AM   #7
Thank you for your help
Old 07-28-2024, 05:12 PM   #8
Is there any damage to anything inside?
Retired Navy Chief is offline   Reply With Quote
Old 07-28-2024, 05:21 PM   #9
No interior damage, everything works as it should and looks like it should.
Old 07-28-2024, 08:18 PM   #10
One issue I ran into when I needed body work done is that many shops paint booths were not tall enough to accommodate the height of my Class B.
olybsnow is offline   Reply With Quote
Old 07-28-2024, 09:45 PM   #11
Default Ditto the booth height
We had to find a place in the Chicago area because of booth height.
kevnancy is offline   Reply With Quote
Old 07-28-2024, 09:55 PM   #12
Default Damage repair
This was my biggest problem, finding a shop with a tall enough bay. Call around first; they all know how tall their bay is.
I got bids from 2 RV dealers and two body shops. Both RV dealers were nearly 3 times higher than the body shops. I asked around about the body shops’ reputation. My mechanic actually had heard good things about one shop and not good about another.
Besides price (which didn’t matter as other person’s fault) the body shop was willing to let me keep my B until the day they needed it. The RV dealers wanted it on their lot in order to keep my place in line; which was 3 months down the road. My shop had it 2 days.
It was a 2 step process; bring it in to decide which parts to order. After parts arrived we set up a day to bring it in. They had already painted the parts.
We were aware of the possibility of internal damage so we weren’t certain how long it might take. Luckily no internal damage and they had the van back to me by end of business the next day.
Tom 98072 is offline   Reply With Quote
Old 07-28-2024, 10:10 PM   #13
Im gave limited places to take it due to booth size. There are already saying they would want the fridge, kitchen cabinet, and wall panels removed.
Old 07-28-2024, 10:11 PM   #14
That’s the same issue I’m having but I’ve found 2 places that can do it.
Old 07-29-2024, 05:14 PM   #15
We had some minor damage to a quarter panel and the only thing the body shop worried about was if the van could fit in their paint booth. The decided they could remove the panel and bumper to paint it in. Best of luck getting this repaired. Shop around for body shops. There are good ones and others not so much.
Boondocker is offline   Reply With Quote
Old 07-29-2024, 05:29 PM   #16
Thank you.
