Old 10-06-2023, 09:59 PM   #1
Default coach battery
I have a 2017 pleasure way Mercedes sprinter and would like to know where the solar batteries are located, and why is there a spot for an other battery in the engine bay, but there is not one there?
mannella is offline   Reply With Quote
Old 10-12-2023, 06:49 PM   #2
Now sure which Pleasure Way you have but I think you are referring to the house battery. In the Plateau it is located at the rear beneath the couch/bed on the left side in a battery well (carpet panel covering). It is a AGM battery. There is room for extra batteries in the engine bay and also under the front passenger seat although you would have to run a heavy gauge wire to connect the batteries in parallel and all the batteries should be the same size, type and age to properly charge and discharge.
Ken
Old 10-12-2023, 07:11 PM   #3
Your batteries are lithium and they’re located under the couch at the back.
The battery tray under the hood is no longer used for a battery and you cannot use it for one. Many folks put tools or hoses or other outside gear that can withstand the heat in that tray.
If you don’t have a manual, you can download one from the PW website along with the brochure (different sections of the website). You should also join the PW Owners group on groups.io with other owners that know your exact rig.
Cheers,
BL
bl_smith25 is offline   Reply With Quote
Old 10-12-2023, 11:00 PM   #4
Oops, I was reading about an 07 PW immediately before I answered and missed the fact it was a 17. Thanks BL for correcting my info.
Ken
Old 10-13-2023, 04:21 PM   #5
This screen shot is a part of the 2024 Sprinter Build and Price web site. An underhood and below passenger seat battery are still options.
2020 Coachmen Galleria 24A
dmb496 is offline   Reply With Quote
Old 10-15-2023, 05:27 PM   #6
Cheers,
BL
the tray under my hood as cables that are rapped in tape, would this be like this from the factory?
