Old 03-03-2022, 01:53 AM   #1
Default CO2 Alarm
Hi all. I can't figure out if the CO 2 detector works properly in my Roadtrek. Attached is a photo showing the testing instructions. A little difficult to read; hopefullyyoucan zoom in. Not sure I understand them. It does beep and flash green, red.
Also what does ppm mean...parts per ?? Also I don't know what kind of tool to use to remove the casing. Thought it was an Alan wrench but noooo that would be too easy.
Thanks,
Marie
organize4u is offline   Reply With Quote
Old 03-03-2022, 02:55 AM   #2
You can google Safe-T-Alert (MTI industries) with your model number and find an instruction sheet download. On my STA alarm model:
A beep every 15sec plus an alternating Red/Green means there has been a malfunction of the alarm. Press the test button. If it doesn't stop, check battery voltage. If ok, replace alarm.
A beep every 25-30 sec plus an alternating RedRed/GreenGreen means that the alarm is at the end of its life and should be replaced.
These instructions apply to the 65 surface and flush mount models.
ppm = parts per million.
Old 03-10-2022, 05:11 PM   #3
organize4u, Hey. it's a CO alarm not a CO2 alarm. Co2 is carbon dioxide like in a fire extinguisher or dry ice. Co is carbon monoxide like in auto exhaust and kills red blood cells.
horacecupp@gmail.com is offline   Reply With Quote
Old 03-10-2022, 06:30 PM   #4
Thanks horacecupp. I realized that mistake just today ��.
Old 03-10-2022, 10:43 PM   #5
Here is the low down on PPM (Parts per Million) and toxicity:
https://www.abe.iastate.edu/extensio...table-aen-172/
Old 03-11-2022, 03:21 PM   #6
Thanks Johnny Fryer.
M
Old 03-12-2022, 10:59 PM   #7
All CO detectors have a lifespan, usually 10 years. And some won't even allow you to replace the battery.
So at least make sure it's not past its end of life.
UKDude is offline   Reply With Quote
Old 03-13-2022, 01:54 PM   #8
It's actually 5 years. I was way overdue. Both LP and CO were dated 2007!
M
Old 03-13-2022, 05:46 PM   #9
M
There's your easy solution!!!
Old 03-13-2022, 06:40 PM   #10
Yes! Got a two in one, ready to install.
Thanks everyone.
Old 03-14-2022, 11:10 PM   #11
Simple install. Now I see my smoke alarm should have been replaced in 2017 also. Finding all kinds of things PO didn't do. I read about photoelectric/ionization alarms but with my small van I'm thinking a plain old smoke alarm will do. Advice?
Old 03-14-2022, 11:10 PM   #12
PS photo is upside-down ��
Old 03-15-2022, 07:06 PM   #13
My Safety Alert replacement, model that showed, was a bit too big for the space. I could have cut a bigger opening, but ended up disconnecting the CO side (Low battery side etc was still fine) and simply put a separate CO Alarm behind the driver's seat. It came with a 5 year battery, so no hookup required.
