Old Today, 02:44 PM   #1
Default charging specs on 2016 RT
does anyone know where I can find info on 2016 roedtrek 190 popular charging system?found solar controller info but nothing on battery charger. looking to go lithium but need my system"s capabilities. thanks
nevranuff@att.net is offline   Reply With Quote
Old Today, 03:18 PM   #2
You may be best off to find the actual shore charger to get make and model so you can track it down and get specifications for it. Roadtrek specs are often incorrect anyway as they changed components fairly often and the literature didn't keep up very well.
It is likely that the charger is under the rear sofa or couch on the passenger side rear behind a panel behind the wheel well inside the van, like the non lithium ones were since 2007 as far as I know. We have a 2007 190P.
I am assuming you have two AGMs in the storage area ahead of the right rear wheel?
Be aware you will also need to address the alternator charging with a lithium swap unless you already have a second alternator and Balmor regulator in place.
Lots and lots of information on this forum about lithium swaps. The swaps are not as "drop in" as many battery sellers will tell you, though, IMO. The swaps on here go from very basic to more sophisticated depending on the individuals goals and budget.
Old Today, 05:39 PM   #3
Thumbs up
thanks. name and model not easily viewed. only serial number is on the side showing. will pull out the mirrors to get a better look.
