Old 09-27-2022, 08:56 PM   #1
Default Caulk
There are a lot of places that are caulked in bath. I’ve replaced some but doesn’t seem to hold as well as original. Recommendations for a specific kind of caulk? Prep of area? Many thanks
Old 09-27-2022, 10:59 PM   #2
I've just used the same stuff as I use in the house for the van bathroom and kitchen.
DAP Kwik Seal in the smaller 5.5 oz tube is easier to handle than a caulking gun.
Usually better result with a smaller hole cut in the nozzle ( 45º) than you think- makes more likely to push the caulk into the gap rather than it sit on top.
Then come back with a wet finger tip to push in and smooth it
as for prep, just have it clean.
Old 09-28-2022, 01:01 AM   #3
@Michael's Avatar
If it was originally silicone, then you'll have to use silicone again. Nothing else will stick to a surface that has silicone residue.
2019 Coachmen Crossfit
Old 09-28-2022, 02:11 PM   #4
Even silicone won't stick to itself. All residue must be cleaned off the surface for new silicone to stick properly.
Old 09-28-2022, 02:17 PM   #5
Yep, and more pure silicone it is the worse it is to stick to. The "siliconized" caulk is normally latex with a bit of silicone in it.
I have mainly switched to urethane caulking which is much more adhesive and stronger than silicone, plus you can get another layer to stick. The slow cure ones can take a long time to dry, when I did our home shower it took over a week to fully cure, but was watertight in about 2-3 days.
Old 09-28-2022, 06:37 PM   #6
What brand & type do you use? I have used Lexel for many years and like it, though it is harder to get a smooth bead than silicone.
Old 09-28-2022, 06:42 PM   #7
I've also used it outside my Express Van drips rails, both sides. Also repaired a roof with it, good stuff I found.
Old 09-29-2022, 01:56 AM   #8
I don't think the manufacturer used a silicone based caulk in the galley and head.
OP has a Pleasure Way, as do I
