Old 01-14-2022, 08:58 PM   #1
Default Cabinet Hinge
1997 face frame hinge. I have a few small doors above the driver's area that are hinged horizontally (they open upward). When I open these doors, they stay open (no pistons). I have similar doors above the bed area on each side. They look the same but don't stay open. I'd like to get hinges for these similar to the ones in the front driver's area, but can't seem to find a spring hinge tensioned to stay open at ~90º.
Does anyone know a source for these?
thanks.glenn
Old 01-14-2022, 10:38 PM   #2
https://www.rockler.com/overhead-bin...hoCtvQQAvD_BwE
North Phoenix - there may be others
Rockler Woodworking and Hardware - Phoenix
4626 East Thunderbird Road, Phoenix
Open today: 9:00 AM - 7:00 PM
(602) 996-3488
Old 01-15-2022, 01:58 AM   #3
Thanks Mike. But my clothing storage area above the beds has doors that are about 20" wide and only 4" high. I'm afraid that the type of hinge you linked would work but be in the way of taking clothes in and out. My hinges look just like the hinges you see on face-frame kitchen cabinetry but seem to be sprung to hold the door open.
Old 01-20-2022, 05:16 PM   #4
Do your existing hinges have any markings that would indicate brand/model? How far do they hold the doors open? Here is something that may work.
https://woodworker.com/sc-hinge-38-i...su-110-339.asp
Tim R. is offline   Reply With Quote
Old 01-20-2022, 05:21 PM   #5
on our old rocknroll tour buses, cabinet doors were held by these
the phillips at the bottom is used to tension the guide to hold door in position
they work well
https://www.amazon.com/NATIONAL-MFG-...93706543&psc=1
Old 01-20-2022, 07:18 PM   #6
Those are both great leads! Thanks. I found one other but as you can see it's a bit......er......pricey
https://www.amazon.com/dp/B005P0H0HQ...v_ov_lig_dp_it
Old 01-21-2022, 03:54 PM   #7
mloganusda's Avatar
You might try Winnebago for hinges as my large cabinet door stay open without any obstruction.
