Old 10-15-2022, 10:37 PM   #1
Default Broken shower pan
Hi:
I have been cracks in shower pans are very common RV's. The PW is notorious for corner and drain cracks. Have anyone here experienced this? How did you repair it? Did you remove the entire pan and reframe the structural support and reinstall the pan?
Any way to prevent this besides not using the bathroom?
Thanks,
Randy Lum
2016 PW Lexor TS
Old 10-20-2022, 05:00 PM   #2
You may want to join the FaceBook Group. Comes up often, and many solutions. I know most who have had the issue, because they purchased some sort of wood raised floor to step on. https://www.facebook.com/groups/1320069544851352/
Old 10-20-2022, 08:32 PM   #3
Many thanks! I am in the FB forum but not that one. That is where I am learning about this issue. Lots of newer owners are experiencing cracked shower pans. PW has not been very helpful. Some owners had the entire shower pan removed and reinforced wood framing. Something about corners and drain being unsupported. Just thought someone had an easier solution.
2016 PW Lexor TS
