Old 09-18-2018, 07:34 PM   #1
Default Broken Plastic valve under sink
Upon getting familiarized with our ‘93 Coachmen we spotted this broken valve under the sink.
Questions
1. Are the gray valves the hot and cold water shut-offs?
2. Where do we obtain replacements?
3. Any tricks to installation..
File Type: jpeg 6E4E9756-D62A-4118-B078-887D0037C2D3.jpeg (675.1 KB, 14 views)
Adriana is offline   Reply With Quote
Old 09-18-2018, 09:35 PM   #2
They could be low point drains. Look under the van to see if a bit of pipe protrudes at those two locations.
Old 09-18-2018, 10:22 PM   #3
I agree with markopolo. I had a rig with that exact same valve for low point drain. Looks like PEX plumbing. I don't know where you would find that exact valve but here are some on Amazon that might be adapted for the purpose:
https://www.amazon.com/s?k=rv+pex+dr...b_sb_ss_i_1_18
Old 09-18-2018, 11:31 PM   #4
Thank you both, they are definitely low point drains. I have seen other owners have replaced them with ball valves, some inside the RV and some outside. Guess I’ll be putting my plumber hat on.
Will there be similar drains for the tub, toilet and fresh water tank or are those the low points for the entire water supply?
File Type: jpg 483F57C5-70DB-44E7-B894-6422EA620F7F.jpg (206.0 KB, 5 views)
