Old 11-22-2021, 06:41 PM   #21
They probably had to drop the tank as it is a Roadtrek which is very tight in that area.
I hope they replaced the rubber hoses there while they were there. I know the grille output is one and there may be one other.
Four hours is fair. It took me two hours to accept the fact that the tank had to be removed and a week to do it. There is no other way.
If you look you will see a short rubber hose between the tank and the regulator. Over the next year look for a place that will make the hose for you. Propane hoses should be replaced every 10 years or so, so keep it in mind.
