Old 11-22-2021, 07:25 PM   #1
Default Bike rack ?
I have just purchased 2 electric Bikes and would like to take them with us on a cross country trip next year, I am looking for advise and recommendation as to what bike rack I should be looking at, My van is a 2011 pleasure way Luxor on a chevy 3500 express chassis, I will need the rack to be a swing away so we can access the two rear doors, the bikes are 60lb each with the batteries on, which they won't be while we are traveling in the van, I was told that a swing away rack cuts the tongue weight in half so I need a light weight but strong unit,
Thanks inadvace, Bob S
rpns51 is offline   Reply With Quote
Old 12-02-2021, 05:01 PM   #2
Kuat makes a great swing away hitch rated up to 400 lbs. Find a platform bike rack and not a hanging rack. There are many to choose from.
JMKirwin is offline   Reply With Quote
Old 12-02-2021, 06:06 PM   #3
Default Bike rack
We use the Thule bike rack for our two electric bikes
Canscot is offline   Reply With Quote
Old 12-02-2021, 07:31 PM   #4
I use this one. My bike weight approximately 70 pounds each, with batteries, which can be removed, but don’t think it’s really necessary, as the rack seems to be a little underrated.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Blazeman is offline   Reply With Quote
Old 12-02-2021, 08:45 PM   #5
here is what we use
https://rockymounts.com/backstage/
One Townie electra
one Blix sol
20 k miles so far no problems
We really like how far is swings away
good hunting
Micgael
mangomike is offline   Reply With Quote
Old 12-02-2021, 08:56 PM   #6
Default Override bike rack
I use the override bike rack. It has held up very well and will swing down to give access. I picked it up on Amazon as well
I went a step further and put a hitch on the front of my 2006 Pleasureway Plateau. The bikes go up front and don’t interfere with anything ! Plus I can see them as we go down the road !
A stowaway box came on my rig when we bought it used. Love this front and back combo !
gjconnolly92 is offline   Reply With Quote
Old 12-02-2021, 10:59 PM   #7
We use a Kuat 2.0 swing away and a Hollywood rack for our two Rad ebikes on our 2020 Pleasureway Plateau FL. I also added led trailor lights on the rack to be more visible when I use the cover. I also remove the batteries to reduce weight since each bike weighs 60lbs w/o batteries.
Dja06422 is offline   Reply With Quote
Old 12-02-2021, 11:05 PM   #8
michaelingp's Avatar
Note that it says "RV use prohibited", which might start the debate on why manufacturers often say this.
Old 12-02-2021, 11:15 PM   #9
That actually refers trailer type RV’s as they sway, and bounce to much. Works great on my Mercedes Benz Sprinter3500 class B van
Old 12-03-2021, 05:18 AM   #10
Well my 2 cents worth is that I don't think swing away and tongue weight have anything to do with each other. I have a cheap Hollywood 2 bike rack and for non-ebikes, and I have also used a Hollywood rack for four bikes. Both swing away. I would expect any rack that goes into a 1 or 2 inch hitch to be sufficient. But I suspect you need a rack that the bikes sit on rather than ones that they hang from. Safe travels.
s
sehsteve@gmail.com is offline   Reply With Quote
Old 12-03-2021, 10:19 PM   #11
RV Use Prohibited
HWDean is offline   Reply With Quote
