Old 06-26-2016, 08:06 PM   #1
Default Best temporary fix a flat tire for Srinter 3500
I won't have a spare with me and in the event of picking up a nail or screw, I may need to temporarily fix it until I can get it properly repaired. What is the best fix in a can so to speak for a Sprinter 3500 Class B van?
slim4511 is offline   Reply With Quote
Old 06-26-2016, 08:12 PM   #2
I've used many cans of fix a flat over the years- the exact brand is not important- probably for a larger tire size you'd need 2 cans...
follow the directions.
after sealed, if you can swap a flat front to the rear- safer if it blows.
when going in for repair- WARN the shop that you have used fix flat- some formulations are flammable.
( who has a spare on the back- and a can of fix a flat)
Old 06-26-2016, 08:49 PM   #3
If your rig has a tire pressure monitoring system both the owner's manual and the fix a flat will warn you about the risk of damaging the TPS sensor in the tire.
Given a choice when stranded without a spare I would take the risk. If there is a usable spare available I would tend to use that instead. Figure that a damaged TPS sensor is probably going to be a couple hundred dollars to have replaced at a facility that has access to the part and will work on your Sprinter.
fwdanielson is offline   Reply With Quote
Old 06-26-2016, 08:52 PM   #4
It sounds like I would be better off having the type of repair kit that uses a plug if I can find the source of the leak as opposed to the type that screws onto the air intake. Correct?
Old 06-26-2016, 11:57 PM   #5
Sure- you may want to practice on an old tire in your driveway- I did, and i do carry a plug kit- but the fix a flat has been better.
either way i am not going to be driving past my first real repair option- my DIY fix is to get me to a better place.
- none of my vehicles use tire pressure monitoring systems.
Old 06-27-2016, 02:42 AM   #6
Doesn't the Sprinter normally come with a standard air compressor and a bottle of TPMS compatible sealant that gets injected into the tire by the compressor to reinflate a flat tire?
At least that is shown in the owner's manual but I bought mine used and it was missing...
