05-03-2022, 06:03 PM
Basic Winegard question
How do I turn that thing off?
It doesn't need to be running day and night. I like to keep my main switch on 24/7, but want to turn off the Winegard. There is no switch, and it doesn't look like it's on its own fuse.
05-03-2022, 06:14 PM
Wineguard makes many products
mike
05-03-2022, 06:18 PM
Connect 2.0 WF2-35B
Just called Thor and they told me they hardwire the Winegard Connect 2.0 WF2-35B to the main switch, so there is simply no way to disconnect it.
Weird.
05-04-2022, 02:38 PM
Originally Posted by Urlauber
Connect 2.0 WF2-35B
Weird.
Is there a wall plate for this unit? If so, remove it, find the 12v+ wire (the fused one) and put a switch on that wire and mount the switch close to the wall plate.
"Il Travato Rosso"
2015 Travato 59g
05-04-2022, 04:09 PM
Does not your antenna have a face plate where the cable connects to your TV? If so, then there is a small button to turn on the amplifier to boost the signal. Just turn it off.
05-04-2022, 09:58 PM
Sorry guys, the Winegard Connect 2.0 WF2-35B is neither a dish nor an antenna booster. It is a WiFi booster and wireless network (4G/LTE) hotspot.
So, there are no plates or anything where a wire would surface to add a switch.
It's not a huge deal, I just don't like that sort of "always on" connection which is very exposed to drive-by hacker-wannabees. Plus, since I don't use it, it just wastes energy (not sure how much and whether it is negligible).
05-05-2022, 02:14 PM
Could you take a photo of unit for better answers? Try to remove it to get to the back wiring so you could add an on/off switch.
05-05-2022, 11:22 PM
It sits on the roof, and looks like this: https://winegard.com/connect-2-4g2/
I guess I'd have to trace the wire and see where it crosses a panel or something where I could add a switch.
05-05-2022, 11:26 PM
Probably easier to trace forward from the fuse in the 12V panel. Just pull fuses until you find the one that feeds it. There is a decent chance that it has a dedicated fuse, which would make the project easy.
05-05-2022, 11:41 PM
Hmmm well I called Thor and they said it is not fused, but hard-wired to the main switch. Could be wrong info, or I misunderstood, but looking over the fuses none says anything related to Winegard or Wifi/Booster/whatnot.
05-05-2022, 11:47 PM
That would be horrible, unless the feed wire is big enough to handle the rated current of the fuse or breaker that feeds the main switch, which seems unlikely.
05-06-2022, 04:44 PM
If you can remove the main fuse switch, you should find the wire from your Wi-Fi booster. Then you could add a switch between the main fuse and Wi-Fi booster. I suspect that all the 12v wires are on a main buss bar like this. https://www.amazon.com/Mofeez-Screw-...823643103&th=1
05-06-2022, 06:37 PM
Thank you, yes that sounds likely. I would need to explore the area near the back of the main switch, which is difficult because for that I have to pull the refrigerator (which may be easy, just that I have never done it.)
12-20-2022, 01:06 AM
I ended up resolving this by brute force - I opened up the "dome", the cover that covers the Winegard, and disconnected the power wire so now it doesn't needlessly use up juice.
Just takes a ladder, screwdriver with correct bit, and 5 minutes to restore it to former glory.
