Old 09-06-2023, 08:30 PM   #1
Default Backup camera/third eye
2015 CS third eye/backup camera.
Bound to happen sooner or later. Backing up I hit an overhang at a strip mall. The overhang survived but our backup camera did not. Has anyone had to replace theirs? Did you find a compatible aftermarket third eye/camera combo? Any help would be greatly appreciated.
K Pearce is offline   Reply With Quote
Old 09-07-2023, 02:09 AM   #2
Default Back-up Camera
I have the backup camera from Auto-Vox. I have the Solar 4 RV model. It is powered by small solar panel. Easy to install since it is wireless. They have other models that may interest you. The FitRV.com website did a review on it about a year or so ago.
JoeM is offline   Reply With Quote
Old 09-07-2023, 02:46 AM   #3
I have a sub $100 system from amazon ( similar at costco) wireless camera image, power tapped into the backup lights ( or taillight) depending when you want image
my screen is mounted on left side of dash so I can see screen and mirror at same time.
I hate that in my toyota I have to look down & away from mirrors and windows to use the rear view camera-
Old 09-08-2023, 12:32 AM   #4
michaelingp's Avatar
I had a backup camera fail and I was able to take just the camera apart and find a manufacturer and model number for it. That way I did not have to worry about the rest of the system.
Old 09-12-2023, 09:35 PM   #5
That is what I did. I found a replacement camera on Amazon for about $30. I was worried that the plug might not be compatible, but it fitted up and fired right up.
Old 09-14-2023, 04:55 PM   #6
YES, see picture of my camera.....
If you get this installed once, you'll probably not have to replace it.
Rhydeen Mobile Electronics
https://rydeenmobile.com/vehicle-cameras/pro-commercial-cameras-monitors/
You'll want this professionally installed.....hiding all the wires back to the front is challenging unless you know what you're doing.
When I put my RV in reverse, I can see everything in the back of the vehicle. With this overhead perspective it's a lot safer and easier to back up.
