Originally Posted by GallenH
I'm still struggling with my house battery: 105AH LifeLine purchased about 7 years ago. Has been living in AZ environment. I can't seem to get the battery up to what my Victron reports as 100% charge. That inability exists whether I'm driving or if I'm charging via converter at home. My latest readings are shown below.
Attachment 14870
On the left is the reading immediately after disconnecting home electrical from RV. On the right is the reading after letting the RV sit for 3 hours off of home electric. I know it's not the best evaluation but the volt readings correspond to what LifeLine indicates should be somewhere between 60-70% SOC.
Any ideas/observations most welcome
Glenn
Are your pix swapped? How do you have more SOC after sitting than fresh off charge?
What it looks like off charge is not what you want to look at.
What you need to see is what is happening at the very end of your charge cycle to see if the battery is really full and if the charger is doing a good job of charging.
Lifeline defines a full battery on charge, as being at 14.1-14.4 volts and at .5%C amps so you would want .5 amps charging at that point. If the voltage is lower or the amps are higher, the battery is not full to Victron spec.
You monitor probably has history in it so you may be able to see that information in that history. Without knowing that there is no way to tell what is going on accurately.
