Old 08-11-2013, 05:24 PM   #1
Default Awning installation
I have a 1985 Dodge camper van (Frontier) version. I found a 9ft Apollo awning what I have to install. Question I have is there wood inside the Fiberglas topper and what would be the best place to install it. Thanks guys. John.
Flying Dutchman is offline   Reply With Quote
Old 08-11-2013, 06:14 PM   #2
Default Re: Awning installation
I doubt you'll find wood in the fiberglass roof sides.
My fiberglass roof (mid-nineties design) has a few wood stringers fiber-glassed to the underside of the top but not on the sides.
My awning is attached with 3 brackets on the passenger side of the van's fiberglass roof. The aluminum brackets are bolted through the fiberglass and have a metal backing plate on the inside. Some vans will have wood backing blocks.
Some vans had awnings brackets installed with rivets but I've read a few reports where a rivet ends up pulling through the fiberglass. If you have to do it that way then try to find a rivet that expands very wide on the inside. A "blind peel" or "banana peel" rivet might spread the load really well. Caulk any holes well to prevent leaks.
This pdf file shows how the awning was installed on Roadtrek vans in the late nineties and should give you some ideas.
http://www.classbforum.com/images/rt...stallation.pdf
Old 08-11-2013, 06:50 PM   #3
Thanks for your help. Can anybody give me a suggestion where to buy little mounts you put on the Van body to put the awning poles in.
Old 08-11-2013, 08:38 PM   #4
The side wall mounts are usually specific to the awning brand. An A&E wall mount won't work with a Fiamma awning for example.
This site: http://www.thesamba.com/vw/forum/vie...r=asc&start=20 has some discussion on Apollo awnings. Scroll down that page to see if yours looks similar.
This company - http://www.dan-marcrvparts.com/awpaandsu.html - says it has Norseman parts.
I'd suggest calling Go Westy - http://www.gowesty.com/ec_view_category.php?id=277 - as well. they might know exactly what you need.
