Old 01-08-2017, 11:35 PM   #1
Default AWNING HELP for DODGE XPLORER
Hi all, I have a 1988 Dodge Xplorer B camper Van and i would like to put a awning on it . what company or name of a awning should i used . The van is about 21 feet long, what size should i use here is a pic. of the van.
Thanks, John[ATTACH]3841988 DODGE XPLORER B CLASS VAN 002.jpg4[/ATTACH]
machado11 is offline   Reply With Quote
Old 01-09-2017, 02:26 AM   #2
My class B awning is 11' 6" and is a box awning. I need to replace it, so I have been doing research lately. Not only do you need to mount it high, but it also requires to spots below the awning so the arms can hook in. I could have gotten a 10' awning a lot cheaper (mine will be around $950) but there are obstacles like the battery box and the fresh water full port that must be avoided. I highly recommend visiting Fiamma Inc. - Products and calling them if you need to. Their support is awesome!
1999 American Cruiser
2003 Club Car GS
rjf7g is offline   Reply With Quote
Old 01-09-2017, 02:27 AM   #3
peppster66's Avatar
The brand of awning on our class b is called Fiamma, very well built, somebody mentioned that GoWesty has really good prices on Fiamma products, hope this helps, take care,,,,
peppster66 is offline   Reply With Quote
Old 01-09-2017, 02:30 AM   #4
GoWesty doesn't offer the full range of sizes. I can't get mine from them! I am going to buy mine directly from Fiamma.
Becky
2003 Club Car GS
Old 01-09-2017, 04:04 AM   #5
yes, I have found parts for fiamma from gowesty ...some of which were less than 1/2 the cost.
as for the legs, we find that attaching the legs to the sides of the van is clumsy as you are forced to walk around them...just go straight to the ground, much easier ( for me, anyway).
In the case of the OP, if we did not have an awning, I would get a 10x10 popup for $100 and use that.
you can also look at your local classifieds
mike
Old 01-12-2017, 02:30 AM   #6
I just ordered our awning today directly from Fiamma...it is not a new install, so I should just have to slip it on the already installed brackets, drill a few holes and screw a few screws.
2003 Club Car GS
